[fdo-internals] Re: insert error control properties with KingOracle
Simon Pelicon simon at sl-king.com
Thu Dec 1 04:02:00 EST 2011
Hi!
This is my sample code. I have no problems inserting strings ,integers and
geometry etc. in one Insert command.
All values are inserted.
*          IInsert  insertCommand =
(IInsert)m_Conn.CreateCommand(CommandType.CommandType_Insert);*
*          insertCommand .SetFeatureClassName("ELECTRO_DATA")*
*          FgfGeometryFactory factory = new FgfGeometryFactory();*
*          IDirectPosition position =
factory.CreatePositionXYZ(Objekt.StartPoint.X, Objekt.StartPoint.Y, 0.0);*
*          IPoint point = factory.CreatePoint(position);*
*          insertCommand.PropertyValues.Add(new
PropertyValue(GEOMETRY_COLUMN, new GeometryValue(factory.GetFgf(point))));*
PropertyValue(ROTATION_COLUMN, new StringValue(bref.Rotation.ToString())));*
*          insertCommand.PropertyValues.Add(new PropertyValue(LAYER_COLUMN,
new StringValue(bref.Layer)));*
*          insertCommand.PropertyValues.Add(new PropertyValue(BLOCK_COLUMN,
new StringValue(bref.Name)));*
PropertyValue(XSCALE_COLUMN, new DecimalValue(bref.ScaleFactors.X)));*
PropertyValue(YSCALE_COLUMN, new DecimalValue(bref.ScaleFactors.Y)));*
PropertyValue(ZSCALE_COLUMN, new DecimalValue(bref.ScaleFactors.Z)));*
PropertyValue(PROJEKAT_COLUMN, new Int32Value(ProjectID)));*
*           reader = command.Execute();*
*           if (reader.ReadNext())*
           *reader.close();*
What are the Oracle Data Types in the Oracle table?
Regards,
Simon
On Wed, Nov 30, 2011 at 4:40 PM, mdelsinne <mdelsinne at gmail.com> wrote:
> If I do declare no geometry column, Oracle ID inserted. If there is a
> geometry column no ID and no primary key.
> But also why he never inserts while the other values is a simple string.
> Have you any idea?
> http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7047193.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20111201/e4501c6c/attachment.html
More information about the fdo-internals mailing list
