[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne mdelsinne at gmail.com
Thu Dec 1 07:58:16 EST 2011
I have an improvement, although I get to build the structure in oracle with
the primary key column and geometric, yet I still can not insert the values ​
in other fields, and also I have a problem ID. I declare my property
autogenerated ID but it says incorrect NULL value for the ID. I continued to
look I'll let you know.
Otherwise it looks in Oracle:
ID (PK, NOT NULL, NUMBER(19))
SDFKEY (VARCHAR2(255byte))
NAME (VARCHAR2(255byte))
URL (VARCHAR2(255byte))
GEOM (SDO_GEOMETRY)
This is normal?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7050418.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
