[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne mdelsinne at gmail.com
Fri Dec 2 11:53:32 EST 2011
I do not IApllySchema each insert but only once, and after I run the insert
command for each object. I managed to generate an ID for each object, Oracle
entered the well geometry, but then Oracle does not want the other fields
that are simple string value.
http://osgeo-org.1803224.n2.nabble.com/file/n7055342/ora.jpg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7055342.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
