[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne
mdelsinne at gmail.com
Wed Dec 14 04:31:00 EST 2011
Hello,
I solved my problem by using the dll KingOracle 3.6, so I use FDO 3.6, but
the dll KingOracle was 3.7. However, I noticed a problem on the table names
with special characters, it is possible to create the table "TABLE_NAME" but
autogenerate ID does not work when the table name complicated, surely it can
not create the sequence for type of table name.
Thank you all
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7092863.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
