[fdo-internals] RE: SQL Server, connection and schema
mdelsinne
mdelsinne at gmail.com
Wed Nov 23 04:30:57 EST 2011
I spotted the problem, in fact everything works fine when the schema does not
exist, but if the schema already exists in the database, it can not apply
the schema:
Cannot add schema to database, it already exist.
But it was when I apply the schema that created the table (feature class)
with the properties in the SQL Server database. So if I do not apply the
schema, I can not use the INSERT statement, since it does not find the
feature class in the database.
Have you any idea?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQL-Server-connection-and-schema-tp7021142p7023797.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
