[fdo-internals] FDO 3.6.0.5104 / MySQL provider
Greg Boone
greg.boone at autodesk.com
Fri Aug 10 09:20:10 PDT 2012
Both the 32 and 64-bit builds should be able to use the same numbered build of MySQL. We have not had to use different builds.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Friday, August 10, 2012 12:13 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FDO 3.6.0.5104 / MySQL provider
Hi all,
I'm trying to "pair" correct libmySQL.dll with FDO 3.6.0 releases for both 32-bit and 64-bit platforms, but it just won't work as expected. Here's the
catch:
1) 64-bit platform:
- FDO 3.6.0.5104 binaries (64-bit)
- libmySQL.dll from MySQL Connector/C 6.0.2 (64-bit)
Above combination works OK, but...
2) 32-bit platform:
- FDO 3.6.0.5104 binaries (32-bit)
- libmySQL.dll from MySQL Connector/C 6.0.2 (32-bit)
...is /not/, as it fails on describe schema or something.
What's the correct libmySQL.dll build to use with FDO 3.6.0.5104 binaries (32-bit)?
Regards,
Maksim Sestic
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-3-6-0-5104-MySQL-provider-tp4994467.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
