[fdo-internals] RE: openssl link error build_thirdparty.bat -p=x64
Greg Boone
greg.boone at autodesk.com
Wed Jan 4 11:59:01 EST 2012
Yes, official builds will be on VC 2010 SP1.
Unofficially, VC2008 builds will continue to be maintained. No formal release of 2008 binaries is planned.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, January 03, 2012 11:45 PM
To: FDO Internals Mail List
Subject: [fdo-internals] RE: openssl link error build_thirdparty.bat -p=x64
Thanks Greg,
I will keep them separate. Are the official builds for FDO 3.7 going to be on VC 2010 SP1? Do we still need to maintain the VC 2008 builds?
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: January 3, 2012 9:58 AM
Hi Trevor,
I recommend building 32 and 64 bit builds in separate directories. Some of the third-party projects are not set up in a manner that makes sharing directories easy.
To setup 64 bit:
setenvironment.bat x64 VC10
To Setup 32 bit:
setenvironment.bat VC10
Regards,
Greg
Sent: Friday, December 30, 2011 2:36 PM
Subject: [fdo-internals] openssl link error build_thirdparty.bat -p=x64
Hi list,
I grabbed fdo trunk and am getting an error running a 64 bit build_thirdparty.bat build (error below). Can 32 bit and 64 bit builds be run from the same tree? Here's what I ran from the command line:
[start shell]
%windir%\system32\cmd.exe /k "C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\vcvars32.bat"
[build fdo]
Building OpenSSL
perl util/copy.pl ".\crypto\buildinf.h" "tmp32\buildinf.h"
Copying: ./crypto/buildinf.h to tmp32/buildinf.h
perl util/copy.pl ".\crypto\opensslconf.h" "inc32\openssl\opensslconf.h"
Copying: ./crypto/opensslconf.h to inc32/openssl/opensslconf.h
lib /nologo /out:lib\Release64\libeay32.lib @C:\Users\twekel\AppData\Local\Temp\nmD6F.tmp
tmp32\x86_64cpuid.obj : fatal error LNK1112: module machine type 'x64' conflicts with target machine type 'X86' [C:\fdo \Thirdparty\openssl\openssl.vcxproj]
NMAKE : fatal error U1077: '"c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64\lib.EXE"' : return co de '0x458' [C:\fdo\Thirdparty\openssl\openssl.vcxproj]
Stop.
Regards,
Trevor
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
