[fdo-internals] Re: Self Build FDO 3.6 fail
Jackie Ng jumpinjackie at gmail.com
Fri Jan 20 05:28:49 EST 2012
The UpdateVersion.exe under Thirdparty\util\UpdateVersion\bin is probably
failing for some reason
The build logs should tell you more information. If there's no build logs,
build the offending solution from within Visual Studio itself, it will write
one out.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Self-Build-FDO-3-6-fail-tp7206616p7207004.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
