[fdo-internals] Re: Self Build FDO 3.6 fail
Jackie Ng
jumpinjackie at gmail.com
Mon Jan 30 00:43:32 EST 2012
Is this the same working dir where you previously attempted to compile for
x86?
If so, you should clean (build/build_thirdparty -a=clean) the WC first (with
setenvironment.bat called for that particular compiler) before attempting a
fresh build targeting a different CPU.
There was some previous talk of the 3rd party projects outputting files to
the same dir for x86 and x64 configurations, creating potential linking
conflicts if you didn't clean before switching CPU platforms.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Self-Build-FDO-3-6-fail-tp3887987p4349744.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
