[fdo-internals] Re: Self Build FDO 3.6 fail
Greg Boone
greg.boone at autodesk.com
Mon Jan 30 09:38:18 EST 2012
Based on my experience, I strongly recommend you build x86 and x64 Thirdparty in separate build trees.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, January 30, 2012 12:44 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Re: Self Build FDO 3.6 fail
Is this the same working dir where you previously attempted to compile for x86?
If so, you should clean (build/build_thirdparty -a=clean) the WC first (with setenvironment.bat called for that particular compiler) before attempting a fresh build targeting a different CPU.
There was some previous talk of the 3rd party projects outputting files to the same dir for x86 and x64 configurations, creating potential linking conflicts if you didn't clean before switching CPU platforms.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Self-Build-FDO-3-6-fail-tp3887987p4349744.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
