[fdo-internals] For review: 64-bit linux compilation support
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 24 04:21:41 PST 2013
Hmm, I guess I've asked for review prematurely.
Nevertheless, I've attached logs of unit tests to ticket 761
http://trac.osgeo.org/fdo/ticket/761
Overview:
FDO - log attached
WMS - log attached
WFS - no unit tests. Couldn't find it (???)
SDF - log attached
SQLite - buffer overflow crash
SHP - log attached
One over-arching problem with all the tests that did run is that the full
suite of tests is not executed (compared to the same tests run for the
32-bit build). It just stops at some arbitrary point without any
explanation. I'm guessing the linux cppunit under Thirdparty is just too
ancient for 64-bit support?
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/For-review-64-bit-linux-compilation-support-tp5029140p5029563.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals
