[fdo-internals] For review: 64-bit linux compilation support
Greg Boone
greg.boone at autodesk.com
Thu Jan 24 06:42:53 PST 2013
>> One over-arching problem with all the tests that did run is that the full suite of tests is not executed (compared to the same tests run for the 32-bit build). It just stops at some arbitrary point without any explanation. I'm guessing the linux cppunit under Thirdparty is just too ancient for 64-bit support?
[GB] Wouldn't it be more likely that the unit test is just hanging? If it was a CppUnit issue I doubt the FDO tests would run.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, January 24, 2013 7:22 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] For review: 64-bit linux compilation support
Hmm, I guess I've asked for review prematurely.
Nevertheless, I've attached logs of unit tests to ticket 761
http://trac.osgeo.org/fdo/ticket/761
Overview:
FDO - log attached
WMS - log attached
WFS - no unit tests. Couldn't find it (???)
SDF - log attached
SQLite - buffer overflow crash
SHP - log attached
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/For-review-64-bit-linux-compilation-support-tp5029140p5029563.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
