[fdo-internals] Making the cmake build usable with MapGuide
Jack Lee jack_lee at live.ca
Sat Jun 15 19:54:36 PDT 2013
Have you tried adding the -Bsymbolic option to the linker.
On 2013-06-14, at 3:41 AM, "Jackie Ng" <jumpinjackie at gmail.com> wrote:
> Hi All,
> Given we're in a lull period now with the next major release of MapGuide/FDO
> not realistically happening for another 6 months, I've had time to tackle
> the cmake problem again to get it to produce binaries that can actually be
> used by MapGuide.
> As suggested by Johan, the stripping of SOVERSIONs and tacking the FDO
> version number to the target name of each public FDO library seems to do the
> trick. MapGuide appears to load FDO sos without issue.
> However there's a strange side effect happening with at least one of the
> providers. The SDF Provider for some reason segfaults trying to release
> cached strings in the BinaryReader class.
> But here the thing: It's not the BinaryReader class in the SDF provider.
> It's the BinaryReader class in the GwsQueryEngine which is part of MapGuide.
> It's as though the wires are crossed somewhere and the SDF provider is using
> the wrong BinaryReader class (from GwsQueryEngine and not from within
> itself). I did a nm symbol comparison of both libSDFProvider.so and
> libMgGwsQueryEngine.so grepped on "BinaryReader" and they do share some
> identically mangled symbols for BinaryReader. Is this causing the crossing
> of the wires?
> There must be something in the cmake build that still not right and is
> causing this strange behaviour. I suspect it's something to do with symbol
> visibility and the linker settings, but this is all new to me. Any ideas?
> - Jackie
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Making-the-cmake-build-usable-with-MapGuide-tp5060074.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
