[fdo-internals] FDO Ubuntu 12 64bit Build
Jackie Ng jumpinjackie at gmail.com
Sun May 26 20:14:14 PDT 2013
My sandbox branch (sandbox/linux64) builds successfully on Ubuntu 12.04
64-bit via automake.
Unit tests however, were failing.
I logged the failures for tests I could run under
(http://trac.osgeo.org/fdo/ticket/761). Didn't proceed much further due to
the higher priority item of getting MapGuide Open Source 2.5 out the door.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-Ubuntu-12-64bit-Build-tp5055606p5055852.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
