[fdo-internals] FDO Ubuntu 12 64bit Build
Greg Boone greg.boone at autodesk.com
Mon May 27 10:16:05 PDT 2013
Ok. I might be able to get my hands on a 64bit testing VM. If that is the case, I will try out your changes, testing and porting to trunk as needed.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Sunday, May 26, 2013 11:14 PM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] FDO Ubuntu 12 64bit Build
My sandbox branch (sandbox/linux64) builds successfully on Ubuntu 12.04 64-bit via automake.
Unit tests however, were failing.
I logged the failures for tests I could run under (http://trac.osgeo.org/fdo/ticket/761). Didn't proceed much further due to the higher priority item of getting MapGuide Open Source 2.5 out the door.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/FDO-Ubuntu-12-64bit-Build-tp5055606p5055852.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
