[fdo-internals] RFC 68 for review
Greg Boone
greg.boone at autodesk.com
Wed Sep 11 16:57:48 PDT 2013
Actually, the logic can be reversed, since 2.0 is the new standard.
- Execute the command without using GIST_GEOMETRY_OPS.
- If the command fails, re-execute using GIST_GEOMETRY_OPS.
- If the error persists, error out.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, September 11, 2013 11:54 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] RFC 68 for review
Re: (b)
The provider still needs to support 1.x. I thought we added if/else conditions or "fail-over" conditions to accommodate this need. For example,
- Execute the command using GIST_GEOMETRY_OPS.
- If the create index command fails using GIST_GEOMETRY_OPS, re-execute without this parameter.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Wednesday, September 11, 2013 11:45 AM
To: fdo-internals at lists.osgeo.org
Hi Greg
(a) What is the difference between the following 2 functions? They seem duplicates of each other. SupportsAnsiQuotes() is never used.
the SupportsAnsiQuotes function is used in all providers derived from the
genericrdbms(sqlserver,odbc...)
and it tells what it does. In the specific case of PostGis, PostGIS actually does support Ansi Quotes But is is the easiest way for having the generic part of the provider to remove the quotes. All the code i've added use the IsCaseSensitive function, i think it's clearer this way.
(b) Why did you remove the use of GIST_GEOMETRY_OPS below?
This is not related to the CaseSensitive patch. The GIST_GEOMETRY_OPS does not exist anymore in version 2.*. Only the 2.* runs on 64 bit server. The GIST_GEOMETRY_OPS key word makes the Fdo Create index failed. Removing it make it to work with the default values.
(c) Can you update your indent/tab to be 4 spaces? That is the expected standard. Also. all tab characters should be replaced by 4 spaces.
oops, i will post another patch tomorrow
(d) I believe you have a memory leak. New and no subsequent delete.
I will check this
Thanks for your comments Greg
Bruno
View this message in context: http://osgeo-org.1560.x6.nabble.com/RFC-68-for-review-tp5077290p5077327.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
