[fdo-internals] Unit Test suite instability
Karsten Winter karsten.winter at autodesk.com
Thu Mar 13 02:24:35 PDT 2014
Hi Jackie
Some of the unit tests are finished now. Here is the result for Win 7
64-bit:
FDO Core: 1 Failure (the same you have)
SDF: OK
SHP: OK
SQLite: OK
GDAL: OK
MySQL: OK
ODBC Access: 12 Failures, 93 Errors (the same you have)
ODBC Excel: 1 Failure, 45 Errors (the same you have)
ODBC Text: 1 Failure, 1 Error (the same you have)
The rest will follow soon.
Best regards
Karsten
View this message in context: http://osgeo-org.1560.x6.nabble.com/Unit-Test-suite-instability-tp5128256p5128710.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
