[fdo-internals] Unit Test suite instability
Jackie Ng jumpinjackie at gmail.com
Thu Mar 13 05:50:04 PDT 2014
My notes about the SHP test failures were correct (on Windows at least)
There were a bunch of test SHP files removed by this revision 6 years ago:
http://trac.osgeo.org/fdo/changeset/3738
These test SHP files were still being referenced in the SHP provider test
suite which caused the CppUnit failures I listed on that spreadsheet.
I restored these SHP files to their expected location (I basically checked
out a pre-r3738 copy of the test data) and the SHP provider test suite
passes on Windows for 32-bit and 64-bit.
I gather these files still existed on your end which is why the SHP tests
are OK. But as it stands, the SHP test suite will fail for anyone who does
not know about this change that was made 6 years ago.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Unit-Test-suite-instability-tp5128256p5128776.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
