[fdo-trac] #57: ArcSDE: Added support for ArcSDE 9.2 client
trac_fdo at osgeo.org
Tue Apr 24 14:33:31 EDT 2007
Reporter: romicadascalescu | Owner: romicadascalescu
Type: defect | Status: new
Priority: minor | Milestone: 3.3.0
Component: ArcSDE Provider | Version: 3.2.0
Severity: 3 | Resolution:
Keywords: service pack | External_id:
Changes (by kidsmake6 at msn.com):
* keywords: => service pack
Comment:
A note that with service pack 2 for arcgis desktop there is a new set of
libraries for arcsde. you can see the files here..-
http://support.esri.com/index.cfm?fa=downloads.patchesServicePacks.viewPatch&PID=66&MetaID=1269#
install-ncUNIX
NOTE: If you are using ArcSDE data sources, you must apply the ArcSDE 9.2
SP 2 client install for your particular platform. Since the ArcGIS 9.2
products share common DLLs, it is important to keep the software release
versions in sync to avoid any software conflicts.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/57#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
