[fdo-trac] #104: PostGIS provider cannot insert features with geometry
FDO trac_fdo at osgeo.org
Tue Aug 28 11:08:53 EDT 2007
 Reporter:  cwilbur           |         Owner:  mloskot
     Type:  defect            |        Status:  assigned
 Priority:  major             |     Milestone:  3.3.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  3                 |    Resolution:
 Keywords:                    |   External_id:
Comment (by cwilbur):
 Jason, Mateusz, that's correct - the last patch is the latest suggested
 fix.
 I'm not sure why you guys are so worried about losing the ability to enter
 3D data when it looks to me like you don't have it now (from
 {{{ApplySchemaCommand::AddGeometryColumn}}}):
     // PostGIS Manual:
     // Strictly compliant OGC geometries cannot have Z or M values.
     // The IsValid() function won't consider higher dimensioned geometries
 invalid!
     // Invocations of AddGeometryColumn() will add a constraint checking
 geometry dimensions,
     // so it is enough to specify 2 there.
     int const dimension = 2;
 I was going to run some tests with 3D data using the second (GeomFromText)
 and third (single quotes around WKB) proposed fixes, but the provider
 currently rejects 3D data completely. I'm guessing that's because it
 creates all geometry columns with 2 dimensions.
 {{{InsertCommand::Execute}}} aborts with an "Unsupported geometry type"
 exception if I pass 3D geometry.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/104#comment:12>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
