[fdo-trac] #17: SHP/SDF: fix various Select/SelectAggregates defects
trac_fdo at osgeo.org
Thu Feb 22 08:32:13 EST 2007
Reporter: pierre.dalcourt at autodesk.com | Owner: Pierre Dalcourt
Type: defect | Status: new
Priority: major | Milestone: 3.2.2
Component: FDO API | Version: 3.2.2
Severity: 3 | Keywords:
External_id: |
== Fixed these SHP/SDF defects ==
SDF: SELECT AGGREGATE FUNCTIONS EXECUTED ON INVALID DATA TYPES FOR THAT
FUNCTION RETURNS A 0.0 VALUE.
SDF: SELECT AGGREGATE FUNCTION MIN AND MAX ON A DATETIME DOES NOT RETURN A
VALID VALUE.
SDF: SELECT AGGREGATE FUNCTION MAX AND MIN ON A STRING DOES NOT RETURN A
VALID VALUE
SHP: CERTAIN SELECT AGGREGATE FUNCTIONS CAUSE ERROR "FETCHING A PROPERTY
VALUE DID NOT MATCH THE PROPERTY TYPE"
SHP: Select using computed field and aggregate function is not supported
but fails to generate an exception
== Other issues addressed ==
- Added Min/Max(string/datetime) support to SDF and SHP, by adding this to
FdoCommonQueryAggregator
- Added full TestCommon support to SDF and SHP unit tests; increased usage
of TestCommon in many places
- Improved error handling in SDF/SHP unit tests (Several tests werent
catching/reporting errors correctly)
- ShpSelectCommand now validates upfront that you are not using aggregate
functions or invalid arguments to functions (e.g. Ceil(String))
- SDF: added SchemaTest.* to OpenSource tests (it doesn't rely on Sdf.lib)
- improved FdoCommonDataReader::GetAggregateFunctions() to handle NULL
select list
- added 3 new TestCommon classes and moved some generic SHP/SDF utilities
to them (see Note To Developers)
- moved some more stuff to TestCommonMiscUtils (see Note To Developers)
Ticket URL: <http://trac.osgeo.org/fdo/ticket/17>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
