#18: MySQL: Reverse-engineer views by default
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: new
Priority: major | Milestone: 3.2.2
Component: MySQL Provider | Version: 3.2.2
Severity: 2 | Keywords: views DescribeSchema
External_id: |
Currently, when a DescribeSchema is done on a MySQL datastore without FDO
MetaSchema, class definitions are generated for tables but not views,
unless one specifies a config document that lists the views to reverse-
engineer.
This enhancement changes the behaviour, when the datastore is opened
without config file, to reverse-engineer views as well as tables.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/18>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
