[fdo-trac] #76: ODBC: SQL Server 2005 system views appearing in
schema description
trac_fdo at osgeo.org
Tue May 29 13:56:14 EDT 2007
#76: ODBC: SQL Server 2005 system views appearing in schema description
Reporter: anonymous | Owner: anonymous
Type: defect | Status: closed
Priority: major | Milestone: 3.3.0
Component: ODBC Provider | Version: 3.2.0
Severity: 2 | Resolution: fixed
Keywords: | External_id:
Changes (by anonymous):
* status: assigned => closed
* resolution: => fixed
Comment:
A fix has been applied. This is a stop-gap solution. It just skips "sys"
and "INFORMATION_SCHEMA" when retrieving schemas from SQL Server. The
issue may be revisited in the future to use either "sysobjects" or
"INFORMATION_SCHEMA" to allow an expert user to gain access to the
suppressed schemas.
Revision: 2757
Author: gavincramer
Date: 1:52:34 PM, Tuesday, May 29, 2007
Message:
Ticket #76 ODBC: SQL Server 2005 system views appearing in schema
description
Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/users_.c
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp
Revision: 818
Author: gavincramer
Date: 1:18:50 PM, Tuesday, May 29, 2007
Message:
description
Modified : /branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/users_.c
Modified :
/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcDescribeSchemaTest.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/76#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
