[fdo-trac] #151: ArcSDE provider: Fix spatial index grid size
trac_fdo at osgeo.org
Thu Oct 25 13:02:26 EDT 2007
Reporter: danstoica | Owner: gregboone
Type: defect | Status: new
Priority: minor | Milestone: 3.3.0
Component: ArcSDE Provider | Version: 3.2.0
Severity: 3 | Keywords:
External_id: |
Some insert unit test failed with this error:
"Stream execute failed. [Spatial index grid is too small (-60)]"
It is documented that the grid size should be 250. Found the grid size was
calculated as 2.5 for an arbitrary spatial context. Adjusted to be at
least 250 at schema creation time.
It is clear why the insert succeeded the first time after class creation
and failed in subsequent runs.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/151>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
