[fdo-trac] #220: Can't check in multiple features created in mysql
FDO trac_fdo at osgeo.org
Thu Jan 10 18:17:10 EST 2008
   Reporter:  gregboone       |       Owner:  gregboone
       Type:  defect          |      Status:  new
   Priority:  major           |   Milestone:  3.3.0
  Component:  MySQL Provider  |     Version:  3.3.0
   Severity:  2               |    Keywords:
External_id:  1030026         |
 1. Launch AutoCAD Map 2009 and create a new drawing
 2. Create a SHP connection and load a set of point data.
 3. Create a FDO connection to a MySQL Server
 4. New a mysql datastore, specify the coordinate system as CA83IIIF
 5. Bulk copy data from SHP to the new MySql data source
 6. Select MySQL connection in FDO, and add the data to the map
 7. Right click the layer in Display manager, select Create -> Create New
 Multipoint school_private_pts
 8. Create three points in the map and press Enter
 9. Click check in toolbar button to check in the new features
 Result: Error message appears, Feature was not saved in the target feature
 source. Failed to insert feature. Shape type mismatch on geometric
 property 'Geometry' of the feature class 'school_private_pts'.
 Expected: New features shall be checked in.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/220>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
