[fdo-trac] #220: Can't check in multiple features created in mysql
FDO trac_fdo at osgeo.org
Thu Jan 10 18:18:28 EST 2008
 Reporter:  gregboone       |         Owner:  gregboone
     Type:  defect          |        Status:  assigned
 Priority:  major           |     Milestone:  3.3.0
Component:  MySQL Provider  |       Version:  3.3.0
 Severity:  2               |    Resolution:
 Keywords:                  |   External_id:  1030026
Changes (by gregboone):
  * status:  new => assigned
Old description:
> 1. Launch AutoCAD Map 2009 and create a new drawing
> 2. Create a SHP connection and load a set of point data.
> 3. Create a FDO connection to a MySQL Server
> 4. New a mysql datastore, specify the coordinate system as CA83IIIF
> 5. Bulk copy data from SHP to the new MySql data source
> 6. Select MySQL connection in FDO, and add the data to the map
> 7. Right click the layer in Display manager, select Create -> Create New
> Multipoint school_private_pts
> 8. Create three points in the map and press Enter
> 9. Click check in toolbar button to check in the new features
> Result: Error message appears, Feature was not saved in the target
> feature source. Failed to insert feature. Shape type mismatch on
> geometric property 'Geometry' of the feature class 'school_private_pts'.
> Expected: New features shall be checked in.
New description:
 1. Launch AutoCAD Map 2009 and create a new drawing[[BR]]
 2. Create a SHP connection and load a set of point data[[BR]]
 3. Create a FDO connection to a MySQL Server[[BR]]
 4. New a mysql datastore, specify the coordinate system as CA83IIIF[[BR]]
 5. Bulk copy data from SHP to the new !MySql data source[[BR]]
 6. Select MySQL connection in FDO, and add the data to the map[[BR]]
 Multipoint school_private_pts [[BR]]
 8. Create three points in the map and press Enter[[BR]]
 9. Click check in toolbar button to check in the new features[[BR]]
 [[BR]]
 Result: Error message appears, Feature was not saved in the target feature
 source. Failed to insert feature. Shape type mismatch on geometric
Ticket URL: <http://trac.osgeo.org/fdo/ticket/220#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
