[fdo-trac] #220: Can't check in multiple features created in mysql
trac_fdo at osgeo.org
Thu Jan 10 18:19:41 EST 2008
Reporter: gregboone | Owner: gregboone
Type: defect | Status: assigned
Priority: major | Milestone: 3.3.0
Component: MySQL Provider | Version: 3.3.0
Severity: 2 | Resolution:
Keywords: | External_id: 1030026
Comment (by gregboone):
This defect has its origins in the manner in which the the AutoCAD map
specific bulk copy process reads schema definitions from a shape file and
creates the resulting schema in MySQL. Since the origin of the schema is a
shape file, there is a limitation on the types of Geometry that can be
created for a specific Shape table. For instance, if the Geometric Type is
Point and the Specific Geometry SubType is Point in the Shape file, this
restriction will be carried forward to the schema definition created in
the MySQL data store. However, once a user has bulk copied data from Shape
to MySQL, there is an implied expectation that the user will be able to
perform an insertion of a multi-point feature due to the fact that MySQL
does support multi-point geometry. The Map DataManager UI reflects this
expectation by displaying both the ‘Create Point’ and ‘Create Multi-Point’
options. This expectation will not be honored by the MySQL provider
because the provider provides an extra level of checking that determines
if the geometry subtypes match. If they do not, an exception is thrown.
This level of checking is only performed in the MySQL and PostGIS
providers and is not present in the other RDBMS or SDF providers.
Therefore, it is prudent to relax the check in the MySQL provider so that
it remains consistent with the other FDO providers.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/220#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
