[fdo-trac] #349: ODBC provider incorrectly read SQL Server views
trac_fdo at osgeo.org
Tue Sep 16 15:56:12 EDT 2008
Reporter: pierrega | Owner: gregboone
Type: defect | Status: new
Priority: blocker | Milestone:
Component: ODBC Provider | Version: 3.3.0
Severity: 3 | Resolution:
Keywords: odbc sql server view | External_id:
Comment (by ksgeograf):
You can select the primary key of an ODBC connection using Maestro:
http://trac.osgeo.org/mapguide/wiki/maestro
You can't select multiple columns as the primary key, but for this
particular problem it may be a usable solution.
You cannot autodetect a primary key on a view, because the view may come
from two tables, each with a primary key. Choosing either or both keys as
the view's primary key won't work in all cases. So for views you are
forced to choose the primary key manually, until some DB guys make
metadata on views describing keys.
I agree with Jason, this is not really anything FDO can solve.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/349#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
