[fdo-trac] #119: PostGIS missing quotes for columns in queries
trac_fdo at osgeo.org
Wed Sep 17 06:11:53 EDT 2008
Reporter: jbirch | Owner: mloskot
Type: defect | Status: assigned
Priority: major | Milestone: 3.4.0
Component: PostGIS Provider | Version: 3.2.2
Severity: 3 | Resolution:
Keywords: quoting | External_id:
Changes (by mloskot):
* keywords: => quoting
* cc: riccardo.vignotto at comune.jesolo.ve.it (added)
Comment:
Recently, Riccardo Vignotto has reported similar problems when using FDO
PostGIS provider from GEOMAP GROUP website (http://www.geomapgis.com/web/
geomap-group/fdo/index.html):
''I see that if you query like this 'SELECT colUMN FROM TaBLe' postgre
convert the query to 'SELECT column FROM table'. But if you use double
quotes like this 'SELECT "colUMN" FROM "TaBLe"' it does not lower the case
of characters. From log files I see that you don’t use double quotes when
querying the db. So this is my suggestion for the next versions of the FDO
provider that you develop.''
I've asked Riccardo to check if he uses a patched version (r3318) of the
provider.
Riccardo, I've added your email to CC of this ticket to keep you notified
about news. I hope you don't mind.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/119#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
