[fdo-trac] #573: ArcSDE provider: implement RFC 22 (enhanced CONCAT)
FDO trac_fdo at osgeo.org
Mon Oct 26 10:45:54 EDT 2009
   Reporter:  danstoica        |       Owner:  dan stoica
       Type:  enhancement      |      Status:  new
   Priority:  major            |   Milestone:  3.5.0
  Component:  ArcSDE Provider  |     Version:  3.4.0
   Severity:  2                |    Keywords:
External_id:                   |
 ArcSDE provider needs changes so it supports CONCAT with unlimited
 parameters.
 Currently:
 - both Oracle and SqlServer do not support more than 2 parameters for
 Concat()
 - Oracle supports only string parameters
 - Oracle doesn't support nested ids, hence cannot use Concat(ToString(id),
 string)
 The solution is to delegate the Concat() functionality to the expression
 engine as done in other cases when certain functions are not supported
 natively.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/573>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
