#574: FDO Provider for PostGIS not connecting in the MGOS 2.x
Reporter: ssddgreg | Owner:
Type: defect | Status: new
Priority: major | Milestone: 3.4.0
Component: PostGIS Provider | Version: 3.4.0
Severity: 1 | Keywords: postgis
External_id: |
I have seached several forums for more than two working days for solution
to error in Windows environment (32-bit) - reporduced on Windows XP and
Windows Server 2003
"Failed to read schema from data source"
The Operation gave the error message. The remote server returned an
error:
(559) MgConnectionFailedExeception.:Cannot establiosh connection."
Please note that PosrGRESQL 8.4 is running well, as well as PostGIS
module. All required DLL files from PostGRESQL 8.4 were copied to the
Program Files\OSGeo\MapGuide\Server\Fdo folder and restarted the MapGuide
Server service.
However, Data Connection was tested successfull without any errors, just
when trying to select the PostGIS data connection, it fails.
The same occurs with the Autodesk MapGuide Studio 2010 when accessing the
MGOS 2.1 beta.
It is an essential step in our solution for our customer and we need to
know, if this works on Windows platforms well. For now, we did not have
any success and would need good support in this. Already reported to
Autodesk for the MGE Studio 2010.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/574>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
