[fdo-trac] #666: XML Schema Reader: check association consistency
trac_fdo at osgeo.org
Tue Jul 20 11:04:39 EDT 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: new
Priority: minor | Milestone: 3.6.0
Component: FDO API | Version:
Severity: 3 | Keywords: XML merge Association Property
External_id: |
When the following steps are done, no errors are reported:
* create a feature schema with 2 classes
* add an association property to one class that references the other
class.
* set the identityProperties and reverseIdentityProperties on the
* Create and XML file that defines the same schema but that has a
different data type for one of the association property's identity
properties
* Use FeatFeatureSchemaCollection::ReadXML, to read the XML file and
merge it with the feature schema
However, there is now an inconsistency between the data types for the
association identity properties and reverse identity properties
Ticket URL: <http://trac.osgeo.org/fdo/ticket/666>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
