[fdo-trac] #666: XML Schema Reader: check association consistency
trac_fdo at osgeo.org
Tue Jul 20 11:10:39 EDT 2010
Reporter: brentrobinson | Owner: brentrobinson
Type: enhancement | Status: closed
Priority: minor | Milestone: 3.6.0
Component: FDO API | Version:
Severity: 3 | Resolution: fixed
Keywords: XML merge Association Property | External_id:
Changes (by brentrobinson):
* status: new => closed
* resolution: => fixed
Comment:
Revision: 5560
Author: brentrobinson
Date: 11:07:34 AM, Tuesday, July 20, 2010
Message:
Ticket#666: Modified FdoSchemaMergeContext to report inconsistencies
introduced into association identity properties.
Modified : /trunk/Fdo/UnitTest/SchemaTest.cpp
Modified : /trunk/Fdo/UnitTest/SchemaTest.h
Added : /trunk/Fdo/UnitTest/schema_ref_err3_master.txt
Modified : /trunk/Fdo/UnitTest/schema_refs_err_master.txt
Modified :
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h
Modified :
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp
Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/666#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
