[fdo-trac] #647: Connection incorrectly requires a database
named the same as the user name to exist
trac_fdo at osgeo.org
Wed Nov 3 09:53:17 EDT 2010
#647: Connection incorrectly requires a database named the same as the user name
to exist
Reporter: mwtoews | Owner: brentrobinson
Type: defect | Status: closed
Priority: major | Milestone: 3.6.0
Component: PostgreSQL Provider | Version: 3.4.0
Severity: 3 | Resolution: fixed
Keywords: | External_id:
Changes (by brentrobinson):
* status: assigned => closed
* resolution: => fixed
Comment:
Revision: 5789
Author: brentrobinson
Date: 9:52:04 AM, Wednesday, November 03, 2010
Message:
Ticket#647: Changed PostgreSQL provider behaviour for connecting when
datastore connection parameter is not specified. Previously, the
connection to the PostgreSQL (via PQsetdbLogin) was done with
database=NULL, meaning that the database defaulted to one named the same
as the user. However, the connect fails if no such database exists.
The fix was to connect to the postgres database when the datastore is not
specified. In PostgreSQL 8.4, this database is always present and all
users have access to it. However, to be on the safe side, if the connect
fails, a 2nd connect with the original behaviour (database=NULL) is tried.
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/connect.c
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/connect.h
Ticket URL: <http://trac.osgeo.org/fdo/ticket/647#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
