[fdo-trac] #720: SQLServerSpatial: more friendly message needed for SQL Server 2000
FDO trac_fdo at osgeo.org
Thu Nov 4 11:06:18 EDT 2010
   Reporter:  brentrobinson      |       Owner:  brentrobinson
       Type:  defect             |      Status:  new
   Priority:  major              |   Milestone:  3.6.0
  Component:  SQLServer Spatial  |     Version:  3.6.0
   Severity:  3                  |    Keywords:  SQLServerSpatial SQL Server 2000 connect
External_id:                     |
 If the SQLServerSpatial provider is used to connect to a version 8.0
 (2000) instance, an exception with message indicating that sys.objects is
 missing is throw.
 SQL Server 2000 does not have spatial handling so it's not worthwhile
 supporting connections to it via this provider. These connections can be
 done using the ODBC provider. However the error message could be made more
 explanatory.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/720>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
