[fdo-trac] #723: Wrong No Data Value
trac_fdo at osgeo.org
Thu Nov 18 11:15:09 EST 2010
Reporter: sgamperl | Owner: gregboone
Type: defect | Status: new
Priority: major | Milestone: 3.6.0
Component: WMS Provider | Version: 3.4.0
Severity: 1 | Keywords: WMS, NullPixelValue, NODATAVALUE
External_id: |
The NullPixelValue Property of the OSGeo.FDO.Raster.IRaster interface is
always 0 if i use the WMS Provider.
I think the code in the function _getNullPixelValue() in FdoWMSImage.cpp
is wrong.
// determine the bits per pixel
double null_val = m_bands[0]->GetNoDataValue(&bSuccess);
if (!bSuccess)
null_val = 0;
If a palette is used in the WMS and then the first color in the palette
would be the no data value. That's wrong.
A NoDataValue of 0 is a valid value.
It shouldn't be set in this function if bSuccess == false.
From outside I can check with the raster.NullPixelValue.IsNull() function
if it has a correct value.
Is there a workaround for the problem?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/723>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
