[fdo-trac] #724: Expression Engine: Execute aggregate select on a
class having a not null base class leads to an exception.
trac_fdo at osgeo.org
Fri Nov 19 10:01:31 EST 2010
#724: Expression Engine: Execute aggregate select on a class having a not null
Reporter: romicadascalescu | Owner: romicadascalescu
Type: defect | Status: new
Priority: major | Milestone: 3.6.0
Component: Utilities API | Version: 3.6.0
Severity: 3 | Keywords:
External_id: |
Execute aggregate select on a class having a not null base class leads to
an exception.
Expression Engine generates a index for properties using property names
from a class definition which gets destroyed leading to
invalid names in the index class.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/724>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
