[fdo-trac] #698: PostgreSQL: Z-coordinate (3D) not supported and misrepresented in AutoCAD Map3D
FDO trac_fdo at osgeo.org
Thu Sep 23 13:16:50 EDT 2010
Map3D
   Reporter:  mwtoews              |       Owner:  badreddinekaroui
       Type:  defect               |      Status:  new
   Priority:  major                |   Milestone:  3.6.0
  Component:  PostgreSQL Provider  |     Version:  3.5.0
   Severity:  3                    |    Keywords:
External_id:                       |
 Currently, Z-coordinate (3D) geometries are not supported.  However, this
 is highly desirable.
 Also, AutoCAD Map3D 2011 can add PostGIS layers with Z-coordinates, but
 they are misrepresented. For example, a four-sided polygon:
 #!sql
 create table test3(gid serial primary key, name text);
 select addgeometrycolumn('public','test3','geometry',26910,'POLYGON',3);
 insert into test3(geometry, name)
 values('SRID=26910;POLYGON((514452.882612015 6252255.92843785
 10.1,514477.777417923 6252277.50262608 11.2,514489.882524277
 6252263.32205739 12.3,514464.987722183 6252241.74786916
 13.3,514452.882612015 6252255.92843785 10.1))', 'A 3D Rectangle')
 This appears as a triangle, with the individual XYZ coordinates appearing
 in different X and Y values in AutoCAD 3D.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/698>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
