[fdo-trac] #699: RDBMS: Fixes for classes with inherited associations and constraints
FDO trac_fdo at osgeo.org
Fri Sep 24 14:42:40 EDT 2010
   Reporter:  brentrobinson     |       Owner:  brentrobinson
       Type:  defect            |      Status:  new
   Priority:  minor             |   Milestone:  3.6.0
  Component:  GenericRdbms API  |     Version:
   Severity:  3                 |    Keywords:  Association Property List Constraint inherited base class
External_id:                    |
 The following fails for MySQL, PostgreSQL and SQLServerSpatial providers:
  * Create a class definition (A)
  * Add an identity property
  * Create a class definition (B).
  * Add an assocation property with class A as the associated class
  * Apply the schema
  * Create a class definition (C) with class B as base class
  * Apply the schema. This will fail with an error indicating that Classes
 B and A are already associated.
 The following fails for the PostgreSQL provider:
  * Add a data property with a list constraint
  * Apply the schema
  * Create a class definition (B) with class A as base class
  * Apply the schema.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/699>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
