[fdo-trac] #762: Support schema overrides allowing tables with
X/Y/Z columns to be configured as point feature classes
trac_fdo at osgeo.org
Tue Apr 19 21:41:28 EDT 2011
#762: Support schema overrides allowing tables with X/Y/Z columns to be
Reporter: jng | Owner: traianstanev
Type: enhancement | Status: new
Priority: major | Milestone:
Component: SQLite Provider | Version: 3.6.0
Severity: 3 | Keywords:
External_id: |
It would be nice if we can override the SQLite logical feature schema
(just like with the ODBC provider) so that tables with X/Y/Z columns can
be defined as point feature classes.
The current workaround is to create a view on the table with a computed
column which is the X/Y/Z column values in its WKT form. Then this view
needs to be registered into the FDO metadata table for the provider to
correctly interpret it as a point feature class.
Not the most pretty and performant solution.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/762>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
