[fdo-trac] #763: Change SQL Spatial Server to use Microsoft
geometry format
trac_fdo at osgeo.org
Thu Apr 21 16:22:07 EDT 2011
#763: Change SQL Spatial Server to use Microsoft geometry format
Reporter: romicadascalescu | Owner: romicadascalescu
Type: enhancement | Status: new
Priority: major | Milestone: 3.7.0
Component: SQLServer Spatial | Version: 3.7.0
Severity: 3 | Keywords:
External_id: |
- Add a convertor from/to FDO/Microsoft geometry format
- Pass the geometry at insert, update and spatial select using binds to
avoid
ToString() conversion
- Move to a new SQL driver DRIVER={SQL Server Native Client 10.0}
- This driver behaves a bit different than the standard one (at least we
can
bind big geometries) and a few things had to be fixed.
Note: in order to be able to use the provider you need to install
Microsoft SQL Server Native Client 10.0
Ticket URL: <http://trac.osgeo.org/fdo/ticket/763>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
