[fdo-trac] #817: ODBC Access: decimal values change when German locale
trac_fdo at osgeo.org
Thu Feb 16 10:55:00 EST 2012
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: GenericRdbms API | Version:
Severity: 2 | Keywords: ODBC FdoIInsert decimal value local comma
External_id: |
Steps:
* set machine locale to German (Germany)
* Create an MS Access database with table with columns:
** id - integer (primary key)
** x - double
** y - double
** value - double
* Create an ODBC DSN for the database
* Using ODBC Provider
** connect to the DSN
** create and execute an FdoIInsert, where value = 5.55. The other
properties can have any valid value
* Check the database in Access. value for the inserted row is 555.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/817>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
