[fdo-trac] #817: ODBC Access: decimal values change when German
locale
trac_fdo at osgeo.org
Thu Feb 16 11:05:45 EST 2012
#817: ODBC Access: decimal values change when German locale
Reporter: brentrobinson | Owner: brentrobinson
Type: defect | Status: assigned
Priority: major | Milestone: 3.7.0
Component: GenericRdbms API | Version:
Severity: 2 | Keywords: ODBC FdoIInsert decimal value local comma
External_id: |
Changes (by brentrobinson):
* status: new => assigned
Comment:
Revision: 6393
Author: brentrobinson
Date: 11:05:05 AM, Thursday, February 16, 2012
Message:
Ticket#817: GenericRdbms: modified inserts and updates to bind columns by
their column type. Previously these column values were bound as strings.
Binding by string was problematic for numeric columns, when the values had
fractional parts. If an insert statement sets the value for a double
column to 5.55, then the provider does a locale-independent ('.' decimal
point) conversion to string ("5.55") and then binds the string. The RDBMS
server then converts it back to a number. However, some servers (e.g.
Microsoft Access) convert using the current locale. The decimal point is
lost, if the locale specifies a ',' decimal point, and the value ends up
as 555.
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcHandler.cpp
Modified : /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcHandler.h
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.h
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.h
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/bind.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/bind.h
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/Driver/geom_srid.cpp
Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/bind.c
Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c
Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h
Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/bind.c
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/bind.h
Modified : /trunk/Providers/GenericRdbms/Src/PostGis/Driver/geom_srid.c
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoExpressionFunctionTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/SQLServerSpatial/SqlServerFdoFilterTest.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/817#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
