[Fdo-trac] [fdo-trac] #940: Get CMake build working again
FDO trac_fdo at osgeo.org
Thu Dec 28 08:31:20 PST 2017
 Reporter:  jng           |        Owner:  jng
     Type:  task          |       Status:  assigned
 Priority:  major         |    Milestone:
Component:  Build System  |      Version:
 Severity:  3             |   Resolution:
 Keywords:                |  External ID:
Description changed by jng:
Old description:
> * ~~Fix broken CMakeLists.txt~~
>  * Verify we can run unit tests in CMake build.
>  * ~~CMake-ify the King Oracle provider~~
>  * ~~Fix message catalogs not being copied (`make install` currently only
> installs `SmMessage.cat`)~~
>  * ~~Fix `com` directory not being copied to `/usr/local/fdo-x.y.z/lib`~~
>  * ~~Ensure library targets are named consistently like their windows
> counterparts~~
>  * Build with ASAN (`-fsanitize=address`) in debug mode
>  * Stretch goal: Functional windows configuration (that we can then
> integrate vcpkg for external thirdparty libraries)
New description:
 counterparts~~
  * Investigate how to strip binaries in release mode
  * Investigate how to use CPack to produce SDK tarballs and deb packages
Ticket URL: <https://trac.osgeo.org/fdo/ticket/940#comment:7>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
