[Fdo-trac] [fdo-trac] #940: Get CMake build working again
trac_fdo at osgeo.org
Sat Dec 30 19:56:48 PST 2017
Reporter: jng | Owner: jng
Type: task | Status: assigned
Priority: major | Milestone:
Component: Build System | Version:
Severity: 3 | Resolution:
Keywords: | External ID:
Description changed by jng:
Old description:
> * ~~Fix broken CMakeLists.txt~~
> * Verify we can run unit tests in CMake build.
> * ~~CMake-ify the King Oracle provider~~
> * ~~Fix message catalogs not being copied (`make install` currently only
> installs `SmMessage.cat`)~~
> * ~~Fix `com` directory not being copied to `/usr/local/fdo-x.y.z/lib`~~
> * ~~Ensure library targets are named consistently like their windows
> counterparts~~
> * Build with ASAN (`-fsanitize=address`) in debug mode
> * Investigate how to strip binaries in release mode
> * Investigate how to use CPack to produce SDK tarballs and deb packages
> * Stretch goal: Functional windows configuration (that we can then
> integrate vcpkg for external thirdparty libraries)
New description:
counterparts~~
* ~~Build with ASAN (`-fsanitize=address`) in debug mode~~
* ~~Investigate how to strip binaries in release mode~~
* ~~Investigate how to use CPack to produce SDK tarballs~~ and deb
packages
Ticket URL: <https://trac.osgeo.org/fdo/ticket/940#comment:8>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
