[Fdo-trac] [fdo-trac] #966: GDAL/SHP unit tests cannot be run locally
FDO trac_fdo at osgeo.org
Wed Jan 23 06:25:24 PST 2019
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  assigned
   Priority:  major    |  Milestone:
  Component:  FDO API  |    Version:
   Severity:  3        |   Keywords:
External ID:           |
 There is a bug somewhere in either the GDAL/SHP unit test code or their
 respective provider that throws off the expected working directory,
 breaking the expected paths for the various test data, causing many false
 positive test failures as a result.
 At a minimum, the workaround is to install FDO and export its lib path to
 {{{LD_LIBRARY_PATH}}} and delete the local {{{providers.xml}}} before
 running the unit test executable. Such a workaround needs to be
 documented.
 Ideally, the underlying problem should be identified and fixed
Ticket URL: <https://trac.osgeo.org/fdo/ticket/966>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
