[Fdo-trac] [fdo-trac] #1024: Queries with coalesced geometries fails
trac_fdo at osgeo.org
Mon Nov 2 03:47:21 PST 2026
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: major | Milestone: 4.2.0
Component: PostgreSQL Provider | Version:
Severity: 3 | Keywords:
External ID: |
Copy from https://trac.osgeo.org/mapguide/ticket/2841
The cause is at the PostgreSQL provider level.
Root cause
A PostGIS view that merges two geometry types (COALESCE(pt, ln) AS geom)
loses its geometry typmod, so geometry_columns reports the column as srid
0 / GEOMETRY even though every row still carries a real SRID:
f_table_name f_geometry_column srid type
v_ticket2841 geom 0 GEOMETRY <- COALESCE view
v_ticket2841_lines geom 25832 LINESTRING <- "l.line AS
geom" view
rows in v_ticket2841: ST_SRID(geom) = 25832 (POINT and LINESTRING)
The provider takes the spatial filter's SRID from that metadata and binds
the filter geometry with it:
FdoRdbmsPostGisFilterProcessor.cpp:199 starts at srid = -1 and fills it
from geomCol->GetSRID() (:207), which is -1 when geometry_columns.srid is
0 (ColumnGeom.cpp:84, fed by the geometry_columns query at
SpatialContextReader.cpp:255).
That SRID travels with the bind value (:271); Geometry.c:317 only sets the
EWKB SRID flag when srid > 0, so the filter geometry arrives at the server
as SRID 0.
The generated SQL is ("geom" && $1::geometry AND
_ST_Intersects("geom",$1::geometry)), and PostGIS rejects the exact
predicate:
ERROR: ST_Intersects: Operation on mixed SRID geometries (Point, 25832) !=
(Polygon, 0)
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1024>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
