[Fdo-trac] [fdo-trac] #1024: Queries with coalesced geometries fails
FDO trac_fdo at osgeo.org
Mon Nov 2 03:52:08 PST 2026
 Reporter:  jng                  |        Owner:  jng
     Type:  defect               |       Status:  closed
 Priority:  major                |    Milestone:  4.2.0
Component:  PostgreSQL Provider  |      Version:
 Severity:  3                    |   Resolution:  fixed
 Keywords:                       |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8431" 8431]:
 {{{#!CommitTicketReference repository="" revision="8431"
 PostgreSQL provider: spatial filters on a geometry column whose SRID is
 unknown
 geometry_columns does not describe a geometry column that carries no
 typmod: a column
 declared as bare "geometry", and every view over an expression -
 COALESCE(point, line)
 being the natural way to merge two geometry types into one column - is
 reported there as
 SRID 0, while the rows it returns keep the SRID they were written with.
 FdoRdbmsPostGisFilterProcessor::ProcessSpatialDistanceCondition took the
 spatial filter's
 SRID from that metadata (FdoSmPhPostGisColumnGeom::GetSRID() reports it as
 -1), so the
 exact predicate compared an SRID-0 literal with a row carrying a real
 SRID:
     "geom" && $1::geometry AND _ST_Intersects("geom", $1::geometry)
 PostGIS rejects that comparison - "ST_Intersects: Operation on mixed SRID
 geometries
 (Point, 4326) != (Polygon, 0)" - as soon as the bounding boxes overlap, so
 the whole
 select fails. The rejection comes from the first FETCH rather than from
 Execute, so a
 caller that is already streaming the result set sees an empty result
 instead of an error;
 MapGuide's SELECTFEATURES over such a view returned no features for either
 geometry type,
 which is what MapGuide ticket 2841 reports
 (https://trac.osgeo.org/mapguide/ticket/2841). A view that selects one
 geometry column
 directly is unaffected, because a plain column reference keeps the typmod
 - which is why
 the report looked like a schema-cache problem.
 When the column's SRID is unknown, the exact spatial predicate - and
 ST_Distance() in the
 distance filter, which takes the same bind and applies the same check -
 now compare by
 coordinate: the column operand is wrapped in ST_SetSRID(...,0) so both
 operands carry the
 same unknown SRID. The && pre-filter deliberately stays on the raw column,
 because it
 ignores SRIDs and needs the cached envelope, so the spatial index still
 prunes; columns
 with a known SRID keep the SQL they had.
 Tests:
 * PostGisFdoSelectTest::TestSpatialFilterWithoutColumnSrid covers a
 COALESCE view over
   point and line columns, a bare geometry column holding SRID-4326 rows,
 and a
   typmod-preserving view as the control case. The filtered view must
 return both geometry
   types, and every advertised spatial predicate plus ST_Distance must keep
 working.
   Without the change it fails with the mixed-SRID error above.
 Verified on ubuntu22 amd64 against the dbs/docker-compose.yml postgis_pg16
 fixture
 (PostGIS 3.4), Debug (ASan/LSan) and Release, through UnitTestPostGis
 initfiletest=...:
 * FdoSelectTest with the provider unfixed: Run: 25, Failure total: 1, that
 failure being
   TestSpatialFilterWithoutColumnSrid; OK (25) with the change.
 * UnitTestPostGis whole suite: OK (141) in both configurations, 140 tests
 before this
   change, and no LeakSanitizer report in the Debug run.
 Fixes #1024
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1024#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
