[Fdo-trac] [fdo-trac] #1007: Replace usage of tempnam with mkstemp in FdoCommonFile
trac_fdo at osgeo.org
Tue Oct 6 07:56:17 PDT 2026
Reporter: jng | Owner: jng
Type: task | Status: closed
Priority: major | Milestone: 4.2.0
Component: FDO API | Version:
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: assigned => closed
Comment:
In [changeset:"8372" 8372]:
{{{#!CommitTicketReference repository="" revision="8372"
FdoCommonFile::GetTempFile(): Generate the temporary name with mkstemp()
instead of tempnam()
tempnam() has been deprecated for decades because the name it returns can
be stolen
between the call and the caller's own open() - GCC warns about it on every
link of every
provider and the suite that actually uses the function ("the use of
`tempnam' is
dangerous, better use `mkstemp'"). The POSIX branch of GetTempFile() now
builds an
"<directory>/idfXXXXXX" template and hands it to mkstemp(), which creates
the file with
owner-only permissions and returns a name nothing else can have taken.
The file mkstemp() creates is closed and unlinked before returning, so the
name still
comes back in the same "unique, but not created yet" state that the
Windows branch
already returns: that branch calls GetTempFileName() and then deletes what
it made, and
the callers (ShpFileSet, ShpSpatialIndex and ShapeIndex) open - and so
create - the name
themselves, some of them with IDF_CREATE_NEW, which fails if the file is
already there.
Leaving the file in place would have been a contract change, so it is
removed as well as
created; the alternative of not creating it at all is what tempnam() did
and what the
warning is about.
Behaviour is otherwise unchanged: the given directory is used when there
is one (a
missing or unwritable directory now fails here rather than at the caller's
open, which is
what the return value documents), an empty path falls back to TMPDIR and
then P_tmpdir
the way tempnam(NULL, ...) did, the name keeps its "idf" prefix and is
still allocated
with new[] for the caller to delete[], and a failure still returns false
with errno set.
Verified against the built library: the returned name is in the requested
directory, does
not exist, is unique across calls, can be created with O_CREAT|O_EXCL and
with
FdoCommonFile::OpenFile(IDF_OPEN_UPDATE|IDF_CREATE_NEW), and nothing is
left behind in the
temporary directory. The SHP suite - the only suite that reaches
GetTempFile, through the
spatial index and fileset temporary-file fallbacks - is still green (OK
(138)) with no
leaks, and the FDO Core suite is unchanged (OK (123)).
Fixes #1007
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1007#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
