[Fdo-trac] [fdo-trac] #891: Sqlite Provider: Access Violation exception in method BuildMetaData()
trac_fdo at osgeo.org
Tue Oct 6 08:56:02 PDT 2026
Reporter: zhanga | Owner: traianstanev
Type: defect | Status: closed
Priority: major | Milestone: 3.9.0
Component: SQLite Provider | Version: 3.9.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8373" 8373]:
{{{#!CommitTicketReference repository="" revision="8373"
SQLite: Re-apply the metadata locking of r7133 in a form that also works
on Linux
r7133 ("#891 Sqlite Provider: Access Violation exception in method
BuildMetaData()") fixed a
Windows access violation caused by two threads building the provider's
metadata cache at the
same time by serializing SltMetadata::BuildMetadataInfo() in
SltConnection::DescribeSchema()
with m_csMd. It was reverted in r7150 because it made the Linux unit tests
hang. The locking
itself was fine; the platform underneath it was not.
STL_CRITICAL_SECTION in SltProvider.h is the Win32 CRITICAL_SECTION on
Windows, which is
recursive - the owning thread may enter it again - but a plain
pthread_mutex_init(m, NULL)
mutex on POSIX, which is not. The metadata build nests:
BuildMetadataInfo() ->
SltMetadata::ProcessViewProperties() -> SltConnection::GetMetadata(),
which takes m_csMd again
for the geometry table of a view. On Windows that inner acquisition just
bumps the recursion
count; on Linux it waited forever on a lock only the waiting thread could
release, which is
exactly the stack in ticket 895 (SelectTest::TestViewSelects ->
SltDescribeSchema::Execute ->
SltMetadata::BuildMetadataInfo -> SltMetadata::ProcessViewProperties ->
SltConnection::GetMetadata -> CriticalSectionHolder, blocked in
pthread_mutex_lock).
The POSIX branch of the abstraction now initializes its mutexes as
PTHREAD_MUTEX_RECURSIVE via
pthread_mutexattr_settype(), so the shim has the semantics the rest of the
provider already
assumes - CriticalSectionHolder and the query-cache code were written for
a lock that can be
re-entered - and on top of that r7133's two m_csMd acquisitions in
DescribeSchema() are
restored: around BuildMetadataInfo() in the requested-class-names branch,
and before
BuildMetadataInfo() in the full-schema path rather than after it.
This also removes a latent deadlock that is in the 4.2 tree today,
independent of r7133:
GetMetadata() already holds m_csMd while calling BuildMetadataInfo(), so
any view whose
geometry table is itself a view was one m_bUseFdoMetadata away from the
same hang.
The three ForceLeaveCriticalSection() calls in the query-cache paths are
left alone. They were
added for the same non-recursive-mutex reason, so they are now redundant
for correctness, but
they also release the lock while sqlite3_reset()/sqlite3_prepare_v2() run,
and changing that
lock hold time is a separate decision.
Verified on the baseline distro (ubuntu22, Debug): with only the
DescribeSchema() locking
applied the suite hangs - single-threaded process, no CPU burned, blocked
in futex_do_wait -
and with the recursive mutex as well it is green again: SelectTest alone
passes (OK (33)) and
the full suite passes (OK (89)) with no leaks, including the
FdoMultiThreadTest query and
insert tests that this locking is meant to protect.
Fixes #891
Fixes #895
Ticket URL: <https://trac.osgeo.org/fdo/ticket/891#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
